2004 Montero Sport Rotor Removal
Old Mar 26, 2008 | 03:13 PM
parrishs8's Avatar
Default 2004 Montero Sport Rotor Removal
I need to remove the right front rotor on my 2004 Montero Sport to have it turned due to a groove. I also plan to replace the pads on both sides. How do I remove the rotor? Looking at it, it appears I can just pull a few bolts and remove the rotor without having to pull the bearings, is this correct? Any help I can get is greatly appreciated.
Old Mar 28, 2008 | 06:44 PM
carlover626's Avatar
Default RE: 2004 Montero Sport Rotor Removal
Is yours 4-wheel drive?If so I believeyou have to remove and repack the bearingsin order toremove the rotor. Haven't done it myself though.
Old Apr 7, 2008 | 02:56 PM
parrishs8's Avatar
It's a 2 WD. I'm going to take of this over the weekend, I'll post my results when I'm done.
Old Apr 8, 2008 | 07:08 PM
Joel_CA's Avatar
You have to remove the grease cover, stap ring, then the hub cover bolts. From there, remove the 2 phillip lock screws, then back out the adjustment collar. Upon reinstallation- the adjustment collar needs to be preloaded to over 100ft/lbs, backed off completely, and torqued to roughly 18ft/lbs. If this isn't done correctly- you will end up with excessive looseness of the wheelbearing after a afew hundred miles. Good luck!
JJ
mlahrens
Jan 29, 2016 06:54 AM
kennyjohn
Sep 23, 2013 06:41 PM
abolbridge
Mar 30, 2013 02:24 PM
Wingo171
Jun 12, 2007 04:18 PM
frohboy33
Apr 7, 2006 02:07 AM
