2005 Montero Limited TPMS MIL
Old Jan 9, 2014 | 04:31 PM
elnico's Avatar
Default 2005 Montero Limited TPMS MIL
Greetings, Fellow Montero Enthusiasts!
I have a 2005 Montero Limited with 70,000+ miles on it.
Last year, the TPMS MIL began flashing and I had it reset by an able mechanic. System was quiet and presumably happy until a period when I did not drive the vehicle for several weeks. Upon starting it, the lamp began flashing again. Said able mechanic has not been available to help me out and I have been looking for means by which to reset the system.
One fellow on the innerwebs instructed that certain pins from the ODB/CAN port could be shorted to the chassis to send a reset signal to the receiver/controller. I looked at his pinouts and they did not seem to match my port setup.
The other technique I was going to use was to open the center console where the controller is located and unplug it/plug it back in, though I am not sure if this will have any effect.
I am trying to avoid spending the $ for a dealer reset if this is going to be a persistent problem. The car will be 15 years next year and nothing lasts forever. My searches of the innerwebs at large yielded no Eureka! moment as to a non-dealer/expensive tpms resetter thingy, so I thought I would come to Montero land and see what insight you fine folks might have.
Thank you in advance for your constructive feedback!
Old May 2, 2019 | 06:51 AM
SpyVito's Avatar
I have this problem. The only thing I could find was that the receivers will tend to go out. Did you ever find a solution?
Old May 7, 2019 | 11:09 PM
I actually hate the new TPMS on most vehicles. Too many false alarms and the fact that you are tied to the shops to do anything with them drives me up the wall. One other solution that is favored by the Click and Clack Brothers is black electrical tape... As long as you check your tire pressure and and confirm that it's OK you are in no danger of using this method.
Sleepytiger86
11
Mar 6, 2021 01:16 PM
tak
Feb 12, 2013 09:28 PM
04 Endeavor
Feb 2, 2011 10:49 PM
marine one
Jun 28, 2009 06:02 PM
FlyinPanda
Nov 19, 2007 10:58 PM
