2wd flashing orange.
Old Aug 25, 2011 | 04:34 AM
Bin's Avatar
Bin
Default 2wd flashing orange.
Hi,
when ever driving my pajero 2004 on 2wd the transmission box in the middle of the dash board car graph starts flashing orange after 30 minutes of driving, but if driving on 4wd no issues?, what is the problem ,is it serious and need immediate fixing? thanks
Old Aug 27, 2011 | 08:07 PM
Mr. Z.'s Avatar
When was the last time you serviced your fluids?
Have you hooked it up to see if it's throwing any codes?
Old Aug 28, 2011 | 03:09 AM
Bin's Avatar
Bin
Hi I did change the fluid just after getting this flashes but did not change the filter( if it is the fluid it should also flashes while on 4wd? am i right) but still the same,the computer found nothing
Old Aug 28, 2011 | 12:50 PM
Mr. Z.'s Avatar
Old Sep 6, 2011 | 03:50 PM
Rougesvp's Avatar
Vacuum valves are sticking, located under airfilter on the Montero... guessing same place on the Pajero, unless a diesel block means they've put them somewhere else. $80-90 and an hour will see you right.
Old Aug 3, 2012 | 05:33 PM
Bin's Avatar
Bin
Hi thanks a lot problem solved it was excatly what you said just cleaned the vaccume valve then no problem
toddrs93
Jun 13, 2010 01:05 PM
gyzmot
Jul 10, 2008 11:09 AM
dorian7
May 6, 2008 02:23 PM
Eclipse Lover
Feb 2, 2008 09:33 PM
novandar
Feb 5, 2005 04:04 PM
