3.5 to 3.8 swap
Old Mar 13, 2010 | 08:14 PM
rsoto's Avatar
Default 3.5 to 3.8 swap
How difficult is to swap a 3.8 Montero Engine in to a 03 Montero Sport with a 3.5?
I'm asking this because when my crankshaft pulley got loosed the crank bolt break causing a mayor repair.
Looking for a used crankshaft in a used part store they tall me it was easiest to put a complete engine but at the moment the only available was a 3.8, there are almost identical, just drop in job.
I did repair my original engine and is working fine?
Have somebody done this swap, are those 300 cc make some difference?
Old Mar 13, 2010 | 10:49 PM
Skiddy's Avatar
Haven't done the swap, however I would check to make sure the wiring is the same. You probably will need the 3.8L PCM as well.
Old Mar 13, 2010 | 11:50 PM
redturboeclipse's Avatar
yea i would imagine it would be easier to do the swap on the 2001-2002 Montero (NOT SPORT), but the big speed bumpbs as mentioned on the CPU, i know the new engines are drive by wire right? no more throttle cable? please correct me if im wrong.
Old Jan 8, 2024 | 11:16 AM
fourbanger41@aol.com's Avatar
Default hello
[QUOTE=rsoto;257111]How difficult is to swap a 3.8 Montero Engine in to a 03 Montero Sport with a 3.5?
Have somebody done this swap, are those 300 cc make some difference? i have already done this in my montero sport and very sweet
fuddy
Jun 19, 2015 12:31 AM
MissouriMonty
Jan 24, 2012 09:50 AM
terokyle
Oct 27, 2009 05:34 PM
monty98
Feb 19, 2009 11:42 AM
tusokuga
May 26, 2006 10:22 PM
