4wd Drive and Possessed Brake Light
Old Dec 8, 2005 | 06:35 PM
OuttaFocus2000's Avatar
Default 4wd Drive and Possessed Brake Light
My Wife's 2003 Montero Sport had the 4H light flash last year but the 4WD still worked at that time. Now the E-Brake light goes on randomly and the 4WD won't engage. Any Ideas?
Old Dec 8, 2005 | 11:17 PM
off roader's Avatar
Default RE: 4wd Drive and Possessed Brake Light
In my 1990, the brake light is triggered by either the Ebrake being up or the brake fluid level in the resevoir being low. Causes for low brake fluid include worn pads requiring more fluid in the lines and therefore less fluid in the reservoir.
Check your brake fluid level and your brake pads for wear. Most likely the cause of the possesed light.
The 4WD light is triggered by a sensor at either the wheels or the transfer case. This sensor can go bad. I'd check there first.
HTH.
Old Dec 9, 2005 | 04:52 AM
Joel_CA's Avatar
Click on my signature to hyperlink over to a Montero Sport forum. From there, you can read the FAQ to take care of both questions asked here. Good LUck!!
Joel, CA
mloweryit
Mar 4, 2013 12:10 AM
qckslvr
Jul 16, 2012 08:10 PM
KenDude
Dec 31, 2010 10:12 PM
EclipseFLAGirl
Nov 9, 2008 11:10 AM
serenabkhan
Nov 23, 2007 05:44 PM
