4wd indicators flashing green
Old Feb 28, 2015 | 09:52 PM
KT1986's Avatar
Default 4wd indicators flashing green
I tried searching here as well as on the web and I cannot seem to find, if any concise answer on this. I went to look at a 1999 Montero (Gen 2.5) and when I test drove it, the lights for the front wheels on the 4WD panel were flashing and there was one light for the passenger side rear wheel on and did not blink at all.
I shifted the transfer case between 2H and 4H and it didnt make a difference at all in the lights. When going around turns, the rear end of the truck hopped, like the rear diff was locked. Tried to go some distance in reverse but that didn't help at all.
I really like this truck but Im afraid that this may be a serious issue and since Im new to Mitsus in general, I wouldnt know the first thing about how to go about troubleshooting this. Any ideas?
Old Feb 28, 2015 | 10:53 PM
Not familiar with your year model Montero, but on a later ones flashing front wheels indicate that the transmission is in the process of engaging the front wheels. As long as the lights are flashing the process is not completed. Since you said shifting from 2H to 4H did not seem to make any difference it is likely to be the case. Honestly, it can be as simple as a bad vacuum line, or as complicated as problem with the front end. Can't really tell.
Regarding the hopping rear end. Does the truck have lockable rear diff? Did you check the tire condition? Do the rear tires look more worn out than the front? Perhaps the rear diff is stuck all together?
Old Feb 28, 2015 | 11:08 PM
KT1986's Avatar
It's the endeavor model with three locking diffs. The rears were replaced at some point before being offered for sale. My guess is the owner was driving with the rear end locked and torched the tires.
It seems that the rear diff is locked and the one wheel cannot freewheel and make a smooth turn. I tried to see if there was any sort of connector for electric at the rear axle but didn't see or feel one. I think I could be wrong about it having 3 locking diffs and the darn thing may just be seized up.
All in all not worth 2500 she's asking
Old Mar 1, 2015 | 12:17 AM
If she's been driving with locked diffs, you have no idea of wear and tear on the rest of transmission and drive train. You are right - it can be a big bag of trouble.
Old Jul 29, 2024 | 02:16 PM
hhughes0320's Avatar
Default Blinking front wheel lights and rear right not on.
2002 Mitsubishi Montero XLS.
I have the exact same issue, i have replaced the solenoid switches near the air filter intake, but no change.
I am going to try the codes for the differential, but my differential light does not light up at all.
Old Sep 1, 2024 | 02:14 PM
I have exactly the same issue as you.
Old Sep 5, 2024 | 11:27 AM
what is the procedure for resetting the ECU? I have never done that before.
I have removed power from via the battery and that is all.
thanks for your help and suggestion.
Howard
HuggyNZ
Dec 16, 2013 05:07 PM
ModyGTS
Feb 8, 2013 11:12 AM
olijayp
Aug 6, 2012 02:53 PM
capricorn1
Jul 21, 2011 07:28 PM
redturboeclipse
May 15, 2011 06:01 PM
