4x4 problems
Old Jan 22, 2007 | 11:40 PM
KENT's Avatar
Default 4x4 problems
I have a 2002 Montero XLS with 130K miles on - only the lower right
light on the dash lights works no matter where the transfer case lever is
2H, 4H or 4L. I suspect that the lower left light bulb is burned out but
I believe that the car is not shifting into 4x4 no matter which position the
transfer case lever is in. Any suggestions as to what might be the problem?
Old Jan 24, 2007 | 01:27 PM
jcasaccio's Avatar
Default RE: 4x4 problems
I had the same issue with my 2003 LTD. It was simply the dashboard bulb. Dealer took care of it under warranty.
Old Jan 29, 2007 | 08:18 PM
soundcolor's Avatar
first, try just changing the bulb...
If that doesnt work...
put it in locked 4wheel drive mode, and jack it up.
place jack-stands under it for safety, and so that you can get all four wheels off the ground. have someone climb in, with the car still running, and still in 4 wheel mode... tell them to GENTLY apply a SMALL amount of throttle until the tires start spinning. If you can only see the rear tires moving, then you have your answer. If however you see both front and rear turning, then you have your answer. Also, Just because they are all turning does not mean that they are functioning properly. Your center diff. could be out, and sending enough power to spin all four wheels in the air, but only routing power to the least grippy wheel when you need it.
does that make any sense at all?
ole
19
Jun 10, 2015 10:47 AM
jp2000
Jan 1, 2012 05:21 PM
donkeeh
16
Jan 29, 2007 08:31 PM
GerardB
Dec 8, 2005 11:20 PM
bull72
Feb 12, 2004 11:18 PM
