6G72 - 12 valve to 24 valve upgrade
Old Jan 10, 2009 | 03:14 AM
Skiddy's Avatar
Default 6G72 - 12 valve to 24 valve upgrade
I've found a decent, low mileage 24 valve 6G72 and I'm wondering if its pretty much "plug and play" when upgrading from a 12 valve. Do I need to replace the ECU, or could I still utilise my own? Thanks.
Old Jan 10, 2009 | 01:05 PM
Hans_GZP's Avatar
Default RE: 6G72 - 12 valve to 24 valve upgrade
You would need quite a bit of items. PS pump, alternator, etc. Wiring harness for the engine as well as an ECU. It's quite an extensive swap. What year montero do you have?
Old Jan 10, 2009 | 01:34 PM
No you could not do it alone. It is all bolt on stuff, but it can get tedious and if you aren't 100% sure what you're doing, it will get ugly.
If you want it that bad, I recommend just buying one.
Old Jan 11, 2009 | 02:16 AM
Skiddy's Avatar
It's a 2000 Pajero. The 24 valve didn't make an appearance in this market until MY2001. If it's really that difficult, then it's not really worth the hassle I suppose. Would be more worthwhile to dump a 6G75 if I'm going to be spending that amount of time/money. Then again, its a daily driver so the 12 valve is pretty decent for what it is. Thank you for the replies.
Shadowplane676
18
Nov 19, 2022 10:28 AM
Hephaestus
Nov 6, 2005 11:31 PM
Shadowplane676
Oct 30, 2005 07:50 PM
m3kgt_99
Aug 25, 2005 09:00 AM
vinceaton
Aug 18, 2005 03:45 PM
