96 Montero SR Front Wheel Assembly Questions..
Old Jun 7, 2012 | 02:19 PM
NCMonteroSR's Avatar
Post 96 Montero SR Front Wheel Assembly Questions..
Hello,
I have a couple of questions...I am a noob to the 4wd wheel assembly deal. But I have what probably be basic questions, and then a real good question.
1. Does the wheels on the Montero freely spin when assembled? I mean is there any resistance at any point while turning it by hand?
I have reassembled the rotors, the bearings, the hub and such. When I turn the wheel with my hand but there seems to be a point that it drags. IS that normal? If not what am I looking at?
2. Is it normal for the axle boot to rotate with the wheel.
3. OK, I have everything assembled according the diagram. However, when I go to place the snap ring in place I am a little sliver shy of clearance for it to sit in the groove. I can't figure out what is keeping it from seating. The only thing that I can think it could be is the rear bearing seal. Every other part goes on only one way. It's pretty cut and dry. So what am I not seeing to get the sliver of clearance I need?
4. The rear bearing seal has a rubber side and a side that has a metal ring in it. Which side faces the wheel.
Thanks for your help!
Gene
Old Jun 7, 2012 | 07:04 PM
mxmikie's Avatar
1-yes 2-yes spins free 3- pull the axle out more 4-metal to wheel
Old Jun 7, 2012 | 11:15 PM
Smile Thanks MX
Thanks a lot. I appreciate it.
jbabywho11
Feb 10, 2012 11:20 PM
redraif
Feb 1, 2012 08:40 PM
pumedon
Aug 17, 2011 03:53 PM
SPELMANITE84
Sep 18, 2006 09:15 PM
kiwicom
Aug 30, 2004 01:32 PM
