'97 Montero Driver Side Window Questions
Old Sep 17, 2017 | 01:13 PM
JimNAZ's Avatar
Default '97 Montero Driver Side Window Questions
Hello!
this window does not work. The motor seems to run (hear it) but it will not raise the window and only slowly lowers the window a couple inches. I can raise the window with my hands.
I have the door panel off but as you know, there is barely any room to try to get in to trouble shoot. From what I can see, the motor is attached to two flexible cables. They both seem to be connected.
I have tried Googling for info and have had no luck. I do not even know how it works to try to trouble shoot.
Any suggestions or help will be greatly appreciated. I new motor with those cables is only $50 so if I need to replace I will not mind but I don't even know how I could get in there to do it!
Thanks
Jim
Old Sep 19, 2017 | 12:06 AM
mxmikie's Avatar
you need to replace it your repair manual or youtube will show you how
GAMitsuBoy
Dec 17, 2017 08:25 AM
XeoNoX
Aug 27, 2012 10:18 AM
pcc183
Jun 3, 2012 09:31 AM
lilaznviper
Jan 30, 2010 11:24 AM
bishigt_18
Nov 1, 2008 07:24 PM
