98 Monero Clicking Sound Drivers Dash
Old Oct 1, 2011 | 10:04 PM
SoCalMonty's Avatar
Default 98 Monero Clicking Sound Drivers Dash
New owner of a 98 Montero and need Help. Recently a clicking sound has randomly appeared under the driver's side dash. Sounds similiar to an electrical relay of some sort. I recently had the ignition switch changed but not sure if that caused anything. Anyone had this before? Common issue with Montero? I am slowly finding the issue with Mitsubishi.
Old Oct 3, 2011 | 06:42 PM
Mr. Z.'s Avatar
Does the sound appear while, or after braking?
Not sure about the Gen II, but the Gen III has a brake boast accumulator that makes a 'clicking' noise when it's going bad. It was a factory recall for my Gen. III.
Good Luck
Old Oct 4, 2011 | 11:00 PM
SoCalMonty's Avatar
Thanks for the reply. I have been trying to get it to repeat itself. Sometimes it won't click at all. Doesn't seem to be when I brake or afterwards but it is hard to re-create. I will take a look at which Gen I have and then go from there. If I give the Vin to the dealer they should know which Gen it is.
Old Oct 5, 2011 | 09:23 PM
Mr. Z.'s Avatar
Your rig is a Gen II.
Check your FSM to see if it has a brake boost accumulator.
If you don't have a FSM, you can find one in PDF on the following site:
Pajero 4x4 Off-Road Club 2000-2008
Good Luck
Gary K
Aug 28, 2012 11:46 PM
Blythetrynity
Sep 8, 2006 09:35 PM
Black98
Apr 9, 2005 11:07 PM
ivant6
Mar 10, 2005 06:43 AM
1rippinGT
Jun 4, 2004 04:28 PM
