Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
00 Diamante No A/C & Clicking Under Dash
Old Aug 28, 2012 | 01:47 PM
Gary K's Avatar
Default 00 Diamante No A/C & Clicking Under Dash
A/C had been working great, but then a clicking started under the dash when I started the car or made an adjustment to A/C temp. After about a week I still have the clicking, but A/C is blowing hot air. Trying to find cause and part failure and have seen terms like "vent control valve", "vacuum control valve", "high and low pressure switch". Looking for help with solution to problem and correct terminology.
I should also add that I an issue with catalytic converter and it ran hot until it was replaced. A lot of that heat made it to the interior and center console. (I understand there may be some thermally sensitive parts under dash).
Thanks in advance for any help you can give me.
Old Aug 28, 2012 | 11:46 PM
mxmikie's Avatar
the clicking is the a/c relay you need to clean your battery cables and make sure the ground wire on the compressor in clean and tight
antifeka
Aug 4, 2017 07:52 AM
SoCalMonty
Oct 5, 2011 09:23 PM
pratzert
13
Aug 10, 2010 02:41 PM
sara
Sep 25, 2008 06:41 PM
Black98
Apr 9, 2005 11:07 PM
