98 montero motor stalls
Old Sep 1, 2008 | 09:14 AM
3dogs's Avatar
Default 98 montero motor stalls
My 98 montero is stalling out. it runs fine then stalls out when i come to a stop - i have to tap the gas to keepit running.what's up?!?
Old Sep 1, 2008 | 09:40 AM
dsm1990gsx's Avatar
Default RE: 98 montero motor stalls
Probably an iac motor.
Old Sep 1, 2008 | 10:14 AM
3dogs's Avatar
i found an article for the dakota/ durango iac fix. is the procedure similar for my 98 montero? if not, any leads to articles/ diagrams for the fix? thanks
Old Sep 1, 2008 | 10:45 AM
No I wouldn't use that.
Do you have a check engine light?
Old Sep 1, 2008 | 10:52 AM
3dogs's Avatar
could you give me both scenarios - w & w/o check engine light? because i saw the light on at a point between stall and startup which could mean it came on as a result of the stall or just before startup [:-]thanks
Old Sep 1, 2008 | 10:55 AM
Well the reason I ask is because you can hook up a diagnostic computer at autozone (for free) and find out what is going wrong.
Old Sep 1, 2008 | 03:10 PM
wallyman's Avatar
Mine has been stalling since new. I was told about the IAC. Right now mine hascheck engine light on but that is for coolant temperature sensor.
Old Sep 1, 2008 | 03:25 PM
Its been stalling for 10 years?
Old Sep 1, 2008 | 04:12 PM
dsm1990gsx's Avatar
ORIGINAL: wallyman
So why dont you get it fixed?
Old Sep 3, 2008 | 02:40 PM
3dogs's Avatar
ORIGINAL: Sebba
the diagnostic checks out ok - no codes showed on their computer - the read-out was "pass". the check engine light is not coming on when this happens which is not often. just taking a preventative approach.
