98 montero motor stalls
RE: 98 montero motor stalls
Have you recently replaced the battery or run down your existing battery to the point of needing a jump start? If so.... Remove the intake hose at the throttle body. Using a rag soaked with throttle body cleaner, open the throttle plate and clean the carbon build up around the bore and the plate itself. Do not spray directly into the the throttle body. When your done, put everything back together and disconnect the negative terminal of the battery for a few seconds. Hook the battery back up and start the car.
liz
04-15-2023 08:42 PM
Bettedaviseyes
06-19-2014 08:16 PM
jacubillo
06-19-2012 09:18 PM
chris carter
10-12-2005 12:40 PM
