98 montero motor stalls
Old Sep 5, 2008 | 02:44 AM
Joel_CA's Avatar
Default RE: 98 montero motor stalls
Have you recently replaced the battery or run down your existing battery to the point of needing a jump start? If so.... Remove the intake hose at the throttle body. Using a rag soaked with throttle body cleaner, open the throttle plate and clean the carbon build up around the bore and the plate itself. Do not spray directly into the the throttle body. When your done, put everything back together and disconnect the negative terminal of the battery for a few seconds. Hook the battery back up and start the car.
liz
Apr 15, 2023 08:42 PM
Bettedaviseyes
Jun 19, 2014 08:16 PM
jacubillo
Jun 19, 2012 09:18 PM
kengo66
Nov 20, 2010 12:22 PM
chris carter
Oct 12, 2005 12:40 PM
