98 montero sport trans problem
Old Jan 13, 2020 | 10:28 PM
tom61's Avatar
Default 98 montero sport trans problem
Hello, any help is greatly appreciated. My truck has recently developed a hard jerk when cold in the morning and shifting into reverse/drive from park. After about two minutes of warmup the problem goes away. Also what transmission do I have? When picking up a trans filter from autozone for the specified model it is not the right one. It is the 3.0L RWD model. Also cold in the morning is around low 40's, not like 0 degrees.
Old Mar 28, 2020 | 11:35 PM
Naeos_Valkarian's Avatar
I just signed up for this forum and I noticed it's been over two months since this post but you will need a tranny filter from 98 jeep grand cherokee. I just replaced mine with part number FK227 from oreilly auto parts. No leaks two weeks later and everything fit perfect. Tranny code is 30-43LE by AISIN.
Old Feb 27, 2021 | 08:52 AM
axelluis's Avatar
I have a Montero sport 1998 W/ 389,000 miles and the same problem of reverse shift.
Actually do not turn over the reverse shift.
Any advise?
regards
Old Mar 2, 2021 | 07:44 AM
Any advise?
regards
Did this no reverse issue suddenly pop up or have you been having issues getting it to go into gear. Slipping, slow shift, hard shift, etc? If it was sudden without warning I'd look into swapping the solenoid that controls the reverse gear. Also when's the last time the tranny had a filter and fluid change.
Now for some other questions, 389K miles is mighty impressive, are you the original owner? Replacement engine or original? Just a curious 98 sport owner.
Old Mar 3, 2021 | 04:39 PM
axelluis's Avatar
It started when I put the reverse it took a few seconds to activate (6 years ago). Then it took longer, so I had to accelerate the engine to activate the reverse and finally it does not activate the reverse for about a year. Sometimes only when the engine is warm and after a long ride. Never the trans oil had replaced. Engine and trans are original. Im the only owner.
Old Mar 4, 2021 | 05:59 AM
Never had the fluid changed? That's spooky, check your transmission fluid level and condition. If you can't check fluid level when hot(after driving) then aim for the cold check, just pull the dip stick when the engine is cold and use the cold mark on the dipstick as a reference, it's not as accurate by a good margin but it does give a decent indicator. If you can drive it to let the transmission get up to operating temperature, run it through all the gears(P,R,N,D,2,L) and then select neutral, engage the parking brake. With engine running, pull the transmission dipstick and see what the fluid level is. You'll be looking for the "hot" side. This is the most accurate way to check the fluid level. If your fluid is black like oil, you need a fluid change, I wouldn't do a flush by any means, especially at that mileage. Use only Mitsubishi Diamond SPIII from the dealership. My apologies if you already know how to do this, just trying to help. After doing this, if it doesn't fix anything, you'd then want to look into more advanced diag. It could be anything at that crazy awesome mileage but we'll start with fluid level and condition.
On another note, that's some awesome mileage to have for an original owner. I wish I could say I was the original owner of mine but it's had three before me and I had to replace the engine at 230K.
HiTeckRedneck
Jul 9, 2019 04:30 AM
AlabamaPajero
Aug 22, 2016 10:30 AM
guangui
Oct 22, 2012 01:40 PM
darius4108
Jun 27, 2004 09:46 PM
sal111
Jan 12, 2004 08:43 PM
