99 Montero Sport XLS- PROBLEMS!
Old Dec 19, 2006 | 05:33 AM
blackdampminer's Avatar
Default 99 Montero Sport XLS- PROBLEMS!
ok,
#1 so my fourwheel drive will engage but the light doesnt come on and the front hubs aren't locking into place.
#2 my anti lock brake light came on in dash, but my brakes are working fine.
anyone got any answers before i take it to the shop?
Old Dec 19, 2006 | 08:16 PM
Manybrews's Avatar
Default RE: 99 Montero Sport XLS- PROBLEMS!
both are probably related to the same common failure, which is a sticking 4wd switch on top of the transfer case.
Sometimes, shifting in and out of 4wd many, MANY times (100-200) may loosen the switch contact so that it works again.
sometimes, you're gonna need to replace a switch or two.
Old Dec 20, 2006 | 03:27 AM
could ya tell me the switch name, so i could order them?
Old Dec 20, 2006 | 04:10 AM
off roader's Avatar
There are multiple switches on top of the transfer case that are tripped when you're in gear.
Old Dec 20, 2006 | 04:40 AM
ok, what would you reccomend on how to replace them and such as far as ordering, just order them all? or what?
Old Dec 20, 2006 | 04:53 PM
off roader's Avatar
Like anything else...
1) test to ensure what's actually bad
2) order & replace.
In the case of these switches, if they are indeed bad, you may have to drop your xcase a bit to get to them. They simply unscrew from the top. Don't forget to check that the wire connections are good as part of step 1 above.
Old Dec 20, 2006 | 08:05 PM
Manybrews's Avatar
there are 3 switches.
seriously, try shifting (in nuetral, not moving) in and out of 4WD a couple hundred times. It may tire your arm out, but it works 90 percent of the time.
Old Dec 21, 2006 | 02:42 AM
thanks a ton guys, im gonna try this tomorrow, just in case i do have to replace one or all of them do you know the proper name or number of the switches?
nashje
25
Sep 20, 2012 05:05 AM
snyderdanno
Apr 16, 2012 06:26 PM
jp2000
Jan 1, 2012 05:21 PM
caverspencer
May 31, 2006 01:53 PM
frohboy33
Apr 7, 2006 02:07 AM
