ABS light comes on when in 4wd
Old Feb 14, 2015 | 05:47 PM
2001Mitch3.5XS's Avatar
Default ABS light comes on when in 4wd
I am driving along in 4wd apply the breaks and the light comes on and I have no assist for breaking in the snow.... WTF !!!!
I turn it off and everything is fine now !!!!
Go figure !!!!
Old Feb 15, 2015 | 02:56 AM
Akzle's Avatar
i dont understand the question
Old Feb 15, 2015 | 06:15 AM
Srry..lol I just read what I wrote.
I am driving along in 4H, Then I applied the breaks to stop and hear the ABS come on, Then the ABS light stays on and I have no more assist from the ABS. I am thinking a fuse or breaker... What are your thoughts on this one....
Old Feb 15, 2015 | 04:43 PM
I had same thing happen once. After a re-start it went away. Was not able to figure out what caused it and it never reoccurred.
Old Feb 16, 2015 | 01:08 AM
Akzle's Avatar
driving on seal in 4h?
driveline wind up. you're lucky you didn't **** your t/fer case - it has happened.
Old Feb 16, 2015 | 01:10 AM
Akzle's Avatar
* causing the electrickery to, in turn, **** itself.
i'm not even entirely sure what abs is.. anti lock brakes? anti brake skidding? assisted bullsh*t steering?
Old Feb 16, 2015 | 03:23 PM
4H is AWD mode - no problem for the pavement. 4HLC is the true 4wd with locked center diff.
Old Feb 17, 2015 | 01:46 AM
Akzle's Avatar
too many f*cking acronyms.
by the sounds of it, wind up has caused your computer to "danger, danger will robinson, does not compute"
-but i don't know **** about computers.
Old Feb 18, 2015 | 02:09 AM
Seriously, unless it starts happening on regular basis i wouldn't worry about it. How many times you had to restart the computer you are on right now? Still works right?
Old Feb 18, 2015 | 04:19 PM
It only did it 1 time but it's all back to normal now .. tks.
