Abs pump
Old Sep 2, 2019 | 03:48 AM
Joelsonmolson's Avatar
Default Abs pump
I have an 01 Montero xls and I'm pretty sure the motor is bad on the assembly. Is an 03 motor compatible? Also read that an 02 4 runner motor can work as well as certain Lexus modles? Hello would be appreciated
Old Sep 2, 2019 | 11:38 PM
Sorry, don't know. But if you confirm compatibility, please post it here. It will be beneficial for all of us to know. Especially interchange with other makers.
Old Sep 3, 2019 | 01:03 PM
larry4406's Avatar
Try one of the online parts catalogs where you enter your year, model, etc. Drill down to the part you need and write the part number down. Then try it again with the 03 year and see if you get the same part number. Once you get the OEM part number, look for aftermarket versions. Then try same on Toyota parts site. Perhaps you can then cross reference the aftermarket part numbers. Will take so google time from you.
One such example
https://mitsubishiparts.com/
Archer12
Sep 30, 2025 06:06 PM
MNalfa
17
May 9, 2019 06:07 AM
timford
Sep 18, 2016 05:09 PM
fallingapart3000gt
May 13, 2006 01:35 PM
deadweasel101
Jul 6, 2004 03:02 PM
