AC Wiring to Interior Controls
Old May 27, 2020 | 09:20 PM
monterogeek's Avatar
Exclamation AC Wiring to Interior Controls
I recently bought a 2003 Montero Sport that the previous owner had AC issues with. My last 03 Montero I had never had any problems with the AC so I'm not familiar with the set up of the wiring, compressor, or relay. It looks like the previous owner, when repairing the AC, wasn't either, and instead of just hooking it all back up to the factory AC button above the stereo, installed a completely different switch (obviously not for a car) on the left side of the steering wheel in the plastic of the dash. Because of this, the AC was not working correctly and working too hard, causing the AC belt to snap, which then made the power steering belt snap. I replaced the belts and recharged the AC, but it is still overworking itself because of how the AC is all DIY rigged in some way I couldn't have even imagined. I don't want the belt to break again because of this, so how do I rewire the AC to the stock button above the stereo?
Please help!
Old May 27, 2020 | 10:26 PM
Naeos_Valkarian's Avatar
Please help!
Check the relays, I did something similar with my AC and had power running through a 50amp switch in the same spot beside the steering wheel. It was only a temporary fix while I saved up money to fix it all right. One of the things I had to do in order to bypass the fried factory AC controls was to rig the relays so they were always closed. This allowed the compressor to run indefinitely but I had to shut it off every so often to avoid the evaporator freezing over. Also check all the AC fuses under the dash and in the engine compartment, may be a burnt fuse in there.
Tyler Zettl
Jan 17, 2012 10:40 PM
Punisher
Mar 7, 2005 02:06 AM
adornare
Feb 4, 2005 10:39 PM
MrRochie
Nov 12, 2004 11:00 PM
mirotrem
Jun 24, 2004 04:29 PM
