Advice on Buying 3rd Gen Montero unseen - rust issues?
Old Oct 8, 2019 | 07:30 AM
1960StudebakerHawk's Avatar
shazbot......Thanks for the detailed report. Glad you finally found one that is the right color and seems to be in great shape. Stupid dealer leaving the wheel lugs loose.......must have boozoos in his shop.
My 94 Montero still had the nice old-fashioned inner/outer bearings. They are great "if" the owner remembers to clean/repack them every so often. When I bought this Montero a year ago, the bearings were in urgent need of fresh grease.....you can see that they only had a thin film of a muddy substance which years ago may have been "grease": The inner/outer races were still in good shape, and the bearings were fine.......but I think they would have been toast if I had not done this.
I also watched a youtube mechanic show how he will use a "grease needle" to add grease to sealed bearings......but then I guess you run the risk of water getting into the bearings. But for an emergency repair, I see nothing wrong with it.
Old Oct 8, 2019 | 07:35 AM
shazbot996's Avatar
Yeah, I've done a bunch of bearings - but as HunterD pointed out - these are replace only. (Thanks for the info!) So I can't service mine... I'll just check them out thoroughly when I go through the brakes.
Found some floor mats for sale by Mitsubishi themselves that I just ordered too! Appears nobody makes the nice aftermarket ones for the Montero, so I'd need to get a "universal" and cut it down. Mitsu factory replacements on the way!
Now I have to start researching stereo replacements. I saw one online where someone had relocated the a/c vent controls to the lower opening to allow a double DIN head unit to be installed.
mystic 3si
Nov 14, 2007 09:09 AM
mitsubishi4life20
Mar 13, 2007 12:36 AM
SCOOT3R
Sep 9, 2006 11:30 AM
Dragonslayer
Jul 25, 2006 08:14 AM
tidus10
Dec 19, 2005 03:41 PM
