Allen Bolts for Locking Hubs
I won't even bother anymore, I just assume spend the 10 or 20 bucks and bammmm your on your way again... Kinda hate to say it but I think the wife is right.... again.....I know my wife is right ALL the time....Good luck bud.
Well...I finally had the bolt removed by a pro. Just $32.16. Took it to Rivers Total Car Care in Oak Ridge, Tn. Same day turn around. Great service. I had tried the dremmel slotting idea first and no luck.
Some of you may find this useful: If you have access to a MIG welder, you can weld a nut to the bolt that is broken off near the surface or above the surface of the hub. I just recently had to remove a lug bolt that was broken flush with the hub on a piece of heavy machinery. We tried to drill the bolt out in order to use an EazyOut. That didn't work at all -the bolt was made from hardened steel and the drill bit didn't even made a dent in it. I positioned a regular nut over the bolt and welded them together (on the inside of the nut). After things cooled off, the nut and bolt just unscrewed out together without any difficulty. I know it only works if you have access to a welder, but its good to know that it is possible to do so.
Shcoons
02-04-2009 08:46 PM
alexxei
08-05-2007 02:15 AM
rcl1221
11-08-2006 07:21 PM
