Allen Bolts for Locking Hubs
Old Feb 4, 2015 | 08:03 AM
2001Mitch3.5XS's Avatar
I won't even bother anymore, I just assume spend the 10 or 20 bucks and bammmm your on your way again... Kinda hate to say it but I think the wife is right.... again.....I know my wife is right ALL the time....Good luck bud.
Old Feb 4, 2015 | 04:42 PM
Unfortunately sometimes you have to bite the bullet.
Old Feb 5, 2015 | 06:26 AM
You got that right... Now bow to her and say "You were right again honey".LOL
Old Feb 5, 2015 | 07:07 PM
LOL. That hurts even more
Old Feb 14, 2015 | 06:02 AM
Ya just gota love it. Hey according to my wife she's right every and ALL the time.lol
Old Feb 15, 2015 | 12:59 PM
Maryville Monte's Avatar
Well...I finally had the bolt removed by a pro. Just $32.16. Took it to Rivers Total Car Care in Oak Ridge, Tn. Same day turn around. Great service. I had tried the dremmel slotting idea first and no luck.
Old Feb 15, 2015 | 04:44 PM
Glad it worked out for you.
Old Feb 18, 2015 | 04:33 PM
Usually the Dreamel won't work like that for that type of bolt but it was worth the try. Glad you got it up and running. Awesome that you stuck with it and accomplished it bud.
Old Feb 18, 2015 | 04:44 PM
Some of you may find this useful: If you have access to a MIG welder, you can weld a nut to the bolt that is broken off near the surface or above the surface of the hub. I just recently had to remove a lug bolt that was broken flush with the hub on a piece of heavy machinery. We tried to drill the bolt out in order to use an EazyOut. That didn't work at all -the bolt was made from hardened steel and the drill bit didn't even made a dent in it. I positioned a regular nut over the bolt and welded them together (on the inside of the nut). After things cooled off, the nut and bolt just unscrewed out together without any difficulty. I know it only works if you have access to a welder, but its good to know that it is possible to do so.
Old Feb 20, 2015 | 05:57 AM
Awesome Hunter, I have done that with a tractor I was working on and it worked like a champ. I think the heat also played a part cause when I put the socket on it to apply pressure it practically fell off... lol
jcosmejr
Dec 2, 2009 08:43 AM
Shcoons
Feb 4, 2009 08:46 PM
duwacker16
Dec 4, 2008 07:35 PM
alexxei
Aug 5, 2007 02:15 AM
rcl1221
Nov 8, 2006 07:21 PM
