battery lossing charge
Old Dec 22, 2015 | 12:11 AM
triciak's Avatar
Default battery lossing charge
My dash lights came on (temp,battery and brake light). Garage said battery and alternator, replaced battery, took alternator to autozone they tested it several times and says it is working properly. What else should we check. It runs then those dash lights come on and eventually car looses power and quits. Any help would be appreciated.
Old Dec 22, 2015 | 07:59 AM
Guyfromhe's Avatar
Did you do a voltage test at the battery with the car running?
Old Dec 22, 2015 | 08:02 AM
triciak's Avatar
Yes and it showed good!
Old Dec 22, 2015 | 08:08 AM
triciak's Avatar
14, then down to 13.9
Old Dec 22, 2015 | 09:23 PM
Guyfromhe's Avatar
I'd check the wiring between the alternator and battery and the main ground connection to the chassis.
Might want to do a voltage drop test and ohm it out.
Old Dec 22, 2015 | 09:26 PM
triciak's Avatar
Thanks, we r actively working on a couple ideas, but running out of ideas quick!
Outlaander
Mar 30, 2015 01:23 PM
Tony1M
Mar 24, 2015 07:31 PM
supracrew
May 4, 2009 06:22 PM
molotov
Nov 29, 2006 08:10 PM
Ray00
Feb 10, 2004 09:58 PM
