best lift for gen 2 montero
Old Nov 24, 2017 | 10:47 AM
JPG3211's Avatar
Default best lift for gen 2 montero
believe it or not I just put 35x12.5 r15 on the stock rims, had to remove some of the plastic off front corner bumpers, and front rear section. I should lift a few more inches as I still get some tire rub on very sharp turns. What is the best way and the best lift kit for Gen 2 Monteros (LS) and has any one got a spare set of RS fender flares? How makes a good after market fender flare that would fit?
Old Nov 24, 2017 | 11:18 PM
Can't answer your question regarding the fender flares. As far as lift kits for Gen2, I think the best one is OME (Old Man Emu) Gen 2 lift kit. The kit includes 4 shocks and 4 springs. It gives you a much better (more stable ride) and lifts the vehicle about 2 inches. Depending on the condition of the bushings on the rear shocks and the condition of the strut mounts on the front, you may be able to re-use those, or you can get new parts to replace them. It is very easy to install it. Perfect fit for the vehicle - no extra modifications or cutting needed.
srennoc75
Oct 30, 2016 10:51 AM
brady1479
Jan 3, 2013 11:51 AM
Offroadingmaniac
Jan 16, 2012 11:36 AM
racinshorty1
May 16, 2007 05:20 PM
Topspin800
Nov 16, 2003 12:32 AM
