Blown tire shredded rear fender flare
Old Mar 22, 2017 | 07:51 PM
montey cosmopolitan's Avatar
Default Blown tire shredded rear fender flare
Hello hello
I had a tire blow out on freeway and the rubber tread separated and whipped the rear fender flare and mud flap off . I'm going to get a replacement at pick a part but I don't know how to remove the flat screws/rivets that hold it to the fender
I hope somebody here has some experience with removing and installing a stock replacement but not from the same scary blow out method
Any and all help is greatly appreciated
Thank you
Attached Thumbnails Blown tire shredded rear fender flare-img_20170322_174228.jpg   Blown tire shredded rear fender flare-img_20170322_174236.jpg
Old Mar 23, 2017 | 01:24 PM
That looks like a pop-rivet. Originally there are regular sheet metal screws there, but they probably got replaced by someone at some point in the vehicle's life. If this is the case - you have to drill out the center of it. Use a large (1/4-1/2") drill bit and carefully drill until you get just through the top part of the rivet. After that, use a narrow punch to remove the back part of the rivet from the fender.
Old Mar 26, 2017 | 01:47 AM
Hey hey
They definitely drilled out easy ... Aluminum ... But the other side are the same rivets ... Go figure ... Now I'm gonna do a little practice removal on some Montero's at pick a part since they don't have any that match mine yet ... Lol
nomanselizabeth
May 6, 2016 08:59 AM
DMCGEE
Jul 11, 2011 09:24 AM
deturner
Sep 12, 2007 06:39 AM
ern
Jan 31, 2007 08:59 AM
xenomorff
Feb 17, 2006 01:20 AM
