A/C Compressor Stalling
Old Jul 21, 2011 | 02:46 PM
p45sc0de's Avatar
Default A/C Compressor Stalling
I'm a new owner of a 2001 Montero Sport and this freaking hot summer has me sweating.
I have gone through 3 A/C belts in the past couple weeks.
The A/C seems to run fine at idle and low rpms. But when it gets over 2500 rpm it acts like the compressor is locking up and the belt squeals/burns and eventually snaps.
I'm wondering if anyone else has had this problem.
Could it be over charged?
Could the expansion valve be failing?
Any suggestions are welcome.
Thanks.
-JP
Old Jul 23, 2011 | 02:51 AM
mxmikie's Avatar
what are the freon pressures ????
Old Aug 4, 2011 | 06:56 PM
leathergoldfish's Avatar
Default I have the same problem
Thanks.
-JP
My solution has been to replace the belts or only drive it in the winter. I have decided its the orifice, and I plan to replace it.
below is a video of while I had gauges on it. ignore my verbal diarrhea, I didn't know what I was talking about.
http://www.youtube.com/watch?v=i9-nm...ature=youtu.be
Old Aug 4, 2011 | 11:24 PM
mxmikie's Avatar
yea what are the pressures ????????????????????????
Old Aug 5, 2011 | 03:37 AM
p45sc0de's Avatar
I have not checked the pressures, but I did try a Gates belt. And so far so good, it's holding up. It's thicker than the Autozone belts I was breaking with much regularity.
So my suggestion is spend the $18 on a Gates belt the first time.
Old Aug 6, 2011 | 06:36 PM
Default mine is fixed
Mine had too much oil in the system, once I bled off extra oil and recharged system, all is working
Old Aug 7, 2011 | 09:56 AM
slimsteele's Avatar
how did you find it had too much oil and how much did you leave in the system
Old Aug 8, 2011 | 05:41 AM
When I put on my gauges it spit oil at me. This compressor doesn't have a drain. I let the high side spray until it stopped spraying. The recharged 134a slowly. I dont know how much oil it has. All I know, it's not too much. I was ready with parts to change the orifice. Not now.
Old Aug 9, 2011 | 08:13 PM
slimsteele's Avatar
Well I think I have mine fixed had to put a expansion valve on mine.
55 to 58 degree vent at idle and 102 outside air I can live with that.
Gregory
Sep 6, 2007 03:17 AM
derf
Oct 12, 2005 06:44 PM
jr2005
Mar 15, 2005 07:25 PM
daemon
Jul 1, 2004 06:08 AM
ChrisandJ
Feb 16, 2004 11:03 AM
