a/c & heat Blower motor 2002 Montero
Old Oct 31, 2009 | 12:54 PM
Carl2002's Avatar
Default a/c & heat Blower motor 2002 Montero
Where is the access to the blower on a Montero LTD ? Mine is making noise like bearing going bad, or maybe trash has gotten thru to the blower..
Old Oct 31, 2009 | 05:54 PM
jrmdir's Avatar
I'm assuming it's basically the same as my '99 - above the passenger foot well. The "ceiling" of the footwell should be made up of a plastic air plenum that is attached to the firewall and center console with push-pin type plastic inserts. Once you remove this plenum the bottom of the fan motor housing is right there. Unplug the connectors, remove the 3 screws and it will fall into your hands. (hopefull along with the offending leaves)
Ron
Old Nov 3, 2009 | 07:06 AM
Carl2002's Avatar
Default Blower motor Montero 2002
Thanks...leaves and noise are gone. Took about 40 mins.
Old Nov 3, 2009 | 09:47 AM
jrmdir's Avatar
Good news!
Thanks for the update.
Ron
Robert Poteete
Dec 27, 2013 02:07 PM
cahoca
Jun 16, 2010 11:41 PM
ilovethekathryn
Feb 3, 2007 05:56 AM
amit_ahuja83
Jul 18, 2006 11:40 AM
hiramabiiff
Jul 9, 2006 01:22 PM
