Can I use Valvoline SynPower 75W90 Gear Oil in differentials?
Old Aug 5, 2018 | 08:44 AM
Brewcity1's Avatar
Default Can I use Valvoline SynPower 75W90 Gear Oil in differentials?
Hey guys....sorry for all the questions.
I searched this forum, and found no clear answer about what differential fluid we are to use.
I thought we needed 80W90 differential fluid for the full sized 3.5 Monteros. Am I correct in this?
I have the 2002 Limited, so I assume that the rear is Limited Slip, so can I use the Valvoline SynPower 75W90 for both front and rear?
I just want to make sure I get the correct fluid before the change.
Also...how many quarts for the front and rear?
Thank you for all the help.
Old Aug 5, 2018 | 05:57 PM
You definitely can use it in the front diff and in the transfer case. Does the Valvoline say its compatible with LSD? If so - go for it.
Old Aug 5, 2018 | 06:03 PM
Brewcity1's Avatar
Thanks so much!! It does say its LSD compatible.
What weight do I use for the fron and rear diff's...and what do I use for the transfer case?
Thanks again for all the help.
Old Aug 5, 2018 | 06:14 PM
FRONT AXLE
Check that the gear oil level is not more than 8 mm (0.3 inch) below the
bottom of the filler plug hole.
Specified gear oil:
Hypoid gear oil API classification
GL-5 or higher, SAE viscosity Number 90, 80W [1.15
dm3 (1.22 quart)]
REAR DIFFERENTIAL
Check that gear oil level is not 5 mm (0.2 inch) below the bot-
tom of filler plug hole.
Specified gear oil:
Hypoid gear oil API classification GL-5 or higher
TRANSFER CASE
Add the oil until the level comes to the lower portion of the
filler plug hole.
Specified oil:
Hypoid gear oil SAE 75W-90 or 75W-85W conforming
to API classification GL-4
Quantity: 2.8 dm3 (3.0 quarts)
Old Aug 5, 2018 | 06:21 PM
Brewcity1's Avatar
FRONT AXLE
Specified gear oil:
dm3 (1.22 quart)]
REAR DIFFERENTIAL
Specified gear oil:
TRANSFER CASE
filler plug hole.
Specified oil:
Thank you HunterD...you are awesome! This is a huge help!
Kip
Sep 19, 2016 06:44 PM
way2fast
Dec 22, 2013 08:54 AM
cdvyas20
Feb 19, 2013 06:24 PM
traskrover
Feb 16, 2011 10:39 PM
Martin86
Jul 3, 2006 04:28 PM
