Can't get the rear camber adjusted.
Old Mar 12, 2018 | 12:18 PM
ckck's Avatar
Default Where can I buy rear camber bolts???
If previous posters are still following--where did you get your rear camber bolts?
I need a camber bolt and toe bolts. All are rusted out. They will have to be cut out and replaced but I can't find the bolts anywhere.
Anyone have a source?
I can't get the rear of the vehicle aligned at all until I get new bolts.
Old Mar 12, 2018 | 05:25 PM
JBiggs's Avatar
Default Bolts
I had the exact same issue with my 01 and now my 03 Montero, I had a trusted shop order them for me or contact a body shop you might know of cause most good ones will have the same book.
Old Apr 24, 2019 | 04:16 PM
FullMonty1958's Avatar
Default Montero alignment bolts
I've been through the gauntlet with rear wheel alignment issues on my 2001 Montero XLS. I almost sheet canned the truck since the local shop wanted $2,500 to fix it, but I did it myself for under $900. The rear camber and toe adjuster bolts were rusted and froze up on the lower control arms and also froze up on the upper toe control arms; preventing any rear wheel alignment or adjustment. I was eating up rear tires in 5-6K miles! I used a sawzall to cut off the old eccentric adjuster bolts (2 lowers and 2 uppers). I then had to replace all 4 control arms since they become unuseable once you cut off the eccentric adjuster bolts. You can order new replacement eccentric cam adjuster bolts off eBay for $6.95 each (free shipping). It's a FEBEST Alignment Cam Bolt, FEBEST Part # 0429-006 for the Rear Lower Control Arms (wheel camber adjustment bolt). If you need to order new replacement eccentric toe adjustment bolts, you need to order a FEBEST Alignment Cam Bolt, FEBEST Part # 0429-005 for the Rear Toe Control Arms. I found FEBEST Auto Parts to be an excellent source for OEM alignment bolts. They also sell the matching washers to go with the eccentric cam bolts for $6.95 each.
Old Apr 25, 2019 | 09:41 AM
wilde's Avatar
Default Possibly don't need to cut them
Mine were all frozen on my 2001 Montero. They didn't look very rusted but probably had Never been adjusted. I couldn't break them free with impact wrench and shop couldn't free them with 6' leverage bar.
I took it home after buying 3 cans of different penetration oils and began this process for 5 days:
Morning---
Tapped back and rear of bolts/nuts for about 30 seconds repeatedly, with a big wrench or small hammer.
Spray them. Tapped again.
Sprayed again.
Evening--
Repeated morning routine.
When I took it back the next week the tech said they all came loose easily. But...he still couldn't get it in spec because the bushings were too old and compressed. So be ready for that problem.
FieroSS
Oct 5, 2010 12:12 AM
metamaster
Oct 22, 2004 01:59 PM
OscarTheGrouch
Jun 18, 2004 05:50 AM
OscarTheGrouch
Jun 18, 2004 05:42 AM
ecp_drv
May 4, 2004 05:00 PM
