Carrier Bearing
Old Dec 22, 2007 | 02:17 PM
Navyboy002's Avatar
Default Carrier Bearing
My 2000 Montero 2x4 has been shaking ever since I got it. Today I was up under it working and grabbed the drive shaft and it has like a good 1/2 inch of play and the rubber is cracked all around. Has anybody ever replaced one of these and if so how does the drive shaft come out. Any help would be great!!!!
[/align]
Old Jan 13, 2008 | 02:02 PM
JNRmonterosport2002's Avatar
Default RE: Carrier Bearing
I have a 2002 montero sport limited, had a vibration, was a loose wheel bearing in the front. I did the same thing you did and was "shocked" the there was so much play. I saw another montero same year and asked if I could check it out. same play. That is not a carrier bearing, just a guide. I posted that question about 5 pages ago and recieved no replies, which I took as a good thing since no one knew enough to make any comment. I agree that any play like that can't be good but it appears to be a common thing.
Old Jan 14, 2008 | 07:51 AM
carlover626's Avatar
I have a 2002 AWD Montero Sport and it has a small vibration in it as well. I thought I would post and let you know that I too have some play in my driveshaft when moved from underneath...
JNR - did you fix the wheel bearing yourself? Any helpful tips? If not, what did it run you to have it corrected at a shop?
Old Jan 15, 2008 | 11:01 PM
ORIGINAL: Navyboy002
My 2000 Montero 2x4 has been shaking ever since I got it. Today I was up under it working and grabbed the drive shaft and it has like a good 1/2 inch of play and the rubber is cracked all around. Has anybody ever replaced one of these and if so how doesthe drive shaft come out. Any help would be great!!!!
[/align]
Hey Navyboy, can you explain the "shaking" you speak of??I am wondering if we have a common problem. Check out the fuel mileage post...I recall reading something about theTorque Converter Clutch(TCC) causinga "vibration".
https://mitsubishiforum.com/m_105430/mpage_1/key_/tm.htm
https://mitsubishiforum.com/m_35021/tm.htm
http://www.4x4wire.com/forums/showfl...v=#Post1012948
Old Feb 6, 2008 | 11:21 AM
floresa66's Avatar
I noticed the same play in the driveshaft, and the rubber support completely worn. My searches for the replacement part have yield no results, I do not even know what is the real name of the part or part number. Did any of you found a solution?
Old Feb 6, 2008 | 12:44 PM
floresa66's Avatar
OK I'll answer my own post LOL. I just found and ordered a new a Center Support Bearing for my 97 Montero Sport. 2wd, 3.0.Hard to find item, but found it at a driveshaft store in San Antonio, Tx. I'll post my comments after I get it and compare.
Old Feb 8, 2008 | 09:47 AM
floresa66's Avatar
LOL I noticed that the mount is damaged on the bottom part (due the weight of the shaft) but OK on top. Since the part is symmetrical, I just turned it 180 degress and Worked!!!! No more shaking!!!. LMAO I got the new support on the mail already but will take more than 15 min. to change it. So for now, I have a smooth running car....
Dafatboy
Jul 14, 2015 06:06 PM
Obakemono
Mar 18, 2012 08:53 AM
JNRmonterosport2002
Feb 6, 2008 11:23 AM
vanorton
Jan 16, 2008 03:43 AM
ilcaa
Feb 26, 2005 07:20 PM
