Checking hydraulic valve adjuster(s)
Old Aug 29, 2005 | 05:06 PM
Scottrik's Avatar
Default Checking hydraulic valve adjuster(s)
I'm in the middle of replacing the valve seals on my '91 RS (grr...this car is my pennance for being a difficult child, I'm sure of it). The car has been making valve noise off and on for some time that sounds like one or more of the hydraulic adjusters maybe oughta should be replaced.
The Haynes manual (with which I am MUCH less than impressed) shows these can be checked by poking a piece of wire through an air bleed hole in the tops of the rockers. Guess what...no holed in the tops of the rockers on my engine. There is what APPEARS to be a check-ball of some sort in the side of the rocker off-set from center but it doesn't seem overly interested in compressing.
Any suggestions or do I just take the shotgun approach and replace all twelve adjusters at $15-20 ea?
Many thanks,
Scottrik
Old Sep 1, 2005 | 03:02 PM
Winshawn's Avatar
Default RE: Checking hydraulic valve adjuster(s)
When you need info that technical goto;
www.4x4wire.com
Old Sep 14, 2005 | 12:11 AM
kawboy636's Avatar
Hydro valve should be self adjusting. If one is bad it may smell burnt. Otherwise if they are making too much noise try a heavier weight (synthetic) oil.
Old Sep 14, 2005 | 02:17 PM
Winshawn's Avatar
You can get all the data that is in the FSM for $25 at www.Alldata.com
Old Sep 14, 2005 | 06:52 PM
DarkManC's Avatar
Those are seld adjsting lash adjusters as mentioned earlier.All you can do is try the heavier weight oil or replace them.That's it!
rayf01
Feb 28, 2014 02:49 PM
ryan6458
Nov 18, 2010 09:53 PM
simjack
Apr 22, 2008 11:16 AM
xtremeone1998
Jun 4, 2005 11:49 PM
rvrexpy
Jan 31, 2005 03:33 PM
