cold idling issue
Old Nov 16, 2021 | 12:07 PM
ceharlow's Avatar
Default cold idling issue
My 1995 montero sr 3.5l has a cold idling issue. I rebuilt the engine ~ 2 years ago, it ran perfect, started first time ever time, till about 30 days ago. All of a sudden ( no changes to vehicle) when the engine is cold, it takes 3-4 attempts to start and will not idle, keeps dying.. if i feather the accelerator to keep it running and drive it till it warms up fully, it runs and idles perfect. i'm assuming the change point is when the engine goes from open loop fueling to closed loop . i have changed the fuel filter and the air/temp sensor unit, no change. there are no error codes occuring. i use a pc software called evoscan, collected a lot of data, but my last of detailed knowledge about what the proper values are for many of the ecid's, i did not identify a problem, i attached the data for your review and feedback, any ideas are greatly appreciated
Old Nov 16, 2021 | 06:28 PM
Can't quite make sence of the data you posted.
Your RPMs fluctuate and drop very low at times. Fuel trims are all over as well. Two things I'd suspect first:
1. Pretty big vacuum leak (busted intake hose or similar)
2. Idle control solenoid issues (IAC).
Old Nov 16, 2021 | 06:48 PM
Naeos_Valkarian's Avatar
Have you tested fuel pressure? It's not unheard of to have a fuel pump present this main symptom and it slowly go away as the engine warms up. The idea is that the exhaust slowly warms up the fuel tank/fuel pump and it's able to operate better. A faulty IAC (Idle Air Control valve) can present the same symptoms as well. I suppose the ICM (Ignition Control Module) could cause this issue as well. I'm not too familiar with the 95 monteros but if it's anything like my 98 sport, the IAC should be attached to the throttlebody right underneath the opening and the ICM should be dead center of the engine above the intake manifold/plenum, right next to where the cam and crank sensors plug into the wiring harness.
Old Nov 17, 2021 | 03:26 PM
ceharlow's Avatar
thanks for the replies, i will look in my service manual to find procedures to test these items. then i'll reply with findings
thanks again
styyy
Dec 16, 2021 02:33 PM
guyjg
Nov 13, 2021 03:27 PM
masood24
Mar 25, 2014 06:39 AM
Galanthighspeeder
Apr 30, 2012 05:01 PM
Hazmat
May 11, 2009 01:09 PM
