crank position sensor
Old Apr 20, 2011 | 06:04 PM
Gunterjaeger's Avatar
Default crank position sensor
Still trying to figure out why my 89 montero suddenly quits. Can anyone tell me where to find the crank sensor and if there is a test that I can perform to check if it is operable
Old Apr 21, 2011 | 08:17 AM
Bump.............................................. ...........
Old Apr 23, 2011 | 05:39 PM
mothman52's Avatar
Hey, no answers yet? Tell me this, does your Montero have a distributor, V6 & a carb or is it a straight in-line 4 ? What's your set-up? If it has a distributor, that's where your Crank Angle Sensor is located, although I can't find any test for it in my manual; the diagnostic if it comes up with a trouble code in the test outlet is two long spikes followed by two short spikes. If your wiring checks out, it says merely to replace the distributor. It says also that the Check Engine Light should light if such a problem with the sensor is detected.
Post-distributor models would have to have this sensor mounted on the engine block in order to gather signals directly from crankshaft rotation, probably towards the rear near the transmission housing, but this is about as much as I know about it.
I'd love to hear from someone around here who's actually met this thing in person.
Old Apr 24, 2011 | 09:33 AM
Thanks for the reply, Mothman! I have a v6 with a distributer and fuel injection. Im trying to track down a stalling issue.
Old Apr 24, 2011 | 09:55 AM
mothman52's Avatar
OK, great. It could be many things, but you've narrowed it down to the Crank Sensor? Let us know what happens....
Zaichik
Jun 4, 2011 09:23 PM
Bastun
Apr 16, 2010 06:05 AM
wannakracka
Dec 2, 2009 03:09 AM
fred170
Jan 14, 2007 11:28 AM
yamahablaster8230
1st Generation
Aug 24, 2006 10:28 PM
