Crankshaft bolt direction
Old May 28, 2019 | 10:18 AM
kc2llw's Avatar
Default Crankshaft bolt direction
Hello,
I am having a problem removing my crankshaft bolt. It is a 2001 Montenegro Limited and I have been spraying it with PB blaster. I am using an impact wrench with 850 lbs of torque. I just want to be sure of the removal direction. I am going in a counterclockwise direction. Any other tips would be appreciated.
Thanks,
Steve
Old May 28, 2019 | 10:48 AM
That bolt has "standard" right handed thread. Counterclockwise is the direction in which you need to turn to remove it. If the bolt has never been removed, it might be an extra PITA... Spraying the bolt with penetrating oil and letting it sit for several days (spray again and again) will help eventually.The biggest issue is to prevent crank shaft rotation while you are trying to break the bolt loose. When I did this job fist time, I did not have a crankshaft holder. I used a 2 ft breaker bar with the handle positioned firmly against the bottom of driver's side fender/frame area of the engine compartment. When everything is secured, you give the engine a quick turn with ON/Off with the key in start position (shut off immediately). That makes the engine turn around the bolt and bolt loosens up. I wouldn't deny - this is a scary and dangerous procedure. DON'T do it if you are not feeling comfortable with it.
Old May 28, 2019 | 10:54 AM
kc2llw's Avatar
HunterD,
Yes i have done that trick with a Honda 3.5 engine once. This is my first Mitsubishi I have worked on. It has a blown head gasket on the passenger side and I am working to remove the heads and this bolt has stopped my progress.
Thanks for the info.
Steve
lgarza
43
Dec 18, 2021 09:51 PM
newoutlanderfan
Apr 20, 2017 11:33 AM
Charles F. MacDonald
Jan 29, 2017 08:34 PM
2slow
Jun 12, 2007 09:22 AM
mmarino
Jun 17, 2004 02:59 AM
