Crankshaft pulley
Old Jan 24, 2014 | 06:56 PM
Anthonyandrew's Avatar
Default Crankshaft pulley
Hi my crankshaft bolt is coming loose and I want to tighten it myself but I'm not sure what torque to set it to.
Old Jan 25, 2014 | 01:55 AM
raskalla's Avatar
1. On Montero Sport models, remove the undercover skid plate. See Fig. 2 .  On Montero models, remove the undercover only.
2. Remove the cooling fan lower shroud. See Fig. 3 .
3. Use special tool MB991367-01 spanner wrench (use with MIT217213 pins for Montero Sport; use with MIT217212 pins for Montero) and a 22 mm socket to hold the crankshaft pulley in place. Remove the crankshaft pulley bolt.
4. Inspect the crankshaft pulley bolt. a. If the bolt is damaged, replace it (see PARTS INFORMATION section of this bulletin). Then continue with step 5 below. b. If the bolt is NOT damaged, go to step 5.
5. Clean the crankshaft pulley bolt hole, the bolt, and washer with compressed air.
6. Apply engine oil to the bolt threads and between the washer and the bolt head faces shown. See Fig. 4 .
7. Reinstall the crankshaft pulley bolt. Torque to 182 + 4 Nm (134 + 3 ft lbs).
8. Reinstall the lower shroud.
9. Reinstall the undercover and skid plate.
Or check this page:
6G74 3.5L DOHC Pajero Cambelt-service - 4x4 Community Forum
Old May 14, 2014 | 12:53 PM
deadreckoning86's Avatar
Default i found a replacement pulley for $163
is there a cheaper option
Old May 15, 2014 | 03:53 AM
Akzle's Avatar
or less. But seriously, how did it come loose
Old May 15, 2014 | 05:16 AM
raskalla's Avatar
Cheaper? How come? Isn't enought? All you need is time and few tools! Try to DIY... don't be laizy
Good luck!
Old May 16, 2014 | 06:01 PM
im doing most of the work myself.
jx_mirage01
Jun 14, 2008 09:02 AM
Angelonia
Nov 15, 2006 04:05 AM
jacek
Dec 25, 2004 01:26 AM
LIQUIDSMILE
Jun 16, 2004 04:36 PM
03eclipseGT
Oct 6, 2003 08:43 PM
