Driveline Vibe?
Old Nov 7, 2010 | 04:33 PM
johnoutdoors's Avatar
Default Driveline Vibe?
Alright guys, here's my problem. At 1500-2000 RPMs I have a vibration in the front end. It feels like I'm going over a washboard dirt road (while on smooth pavement) for a second or two. The RPMs spike just a bit when it happens. It happens repeatedly as long as I'm within 1500-2000 RPMs. It never occurs outside of the above RPM range. Any suggestions on where to start looking?
Old Nov 8, 2010 | 07:27 AM
MitJsus's Avatar
The washboard feeling is referred to as transmission shudder. I would bet on this being your issue. I'm not an expert on transmissions, but I believe it is related to the torque converter. I had this issue in a Lincoln Town Car once. A transmission fluid and filter change, along with a bottle of Lubegard Automatic Transmission Protectant solved my problem. If you use Lubegard, you should check to make sure it is safe for Mitsubishi transmissions. I believe there are other things (electronics) that can cause transmission shudder besides your ATF and filter.
Old Nov 8, 2010 | 12:15 PM
Thanks I'll check that out.
mpasman
Jul 24, 2012 04:16 AM
rclem
Jan 12, 2009 02:09 PM
