Driving and it shut off
Hi Michael,
I've had same issue recently with mine, and found one connector (at control unit near driver seat) with short, causing it shut off random. The wire fail turn off my fuel pump, so, i did a bypass at that connector.
Take your time, check first if the pump is receiving power. If not, do a bypass with a long wire, to test. If goes on, you gonna need time to check all the wire from back to front, passing below the seats, etc. Verify the wires and connectors to the fuel pump.
