Driving and it shut off
Old Feb 28, 2020 | 04:07 PM
Michael Mintz's Avatar
Default Driving and it shut off
I was driving and my truck just shut off I replaced the fuel pump but it doesn’t seem like there’s any power to the pump I cannot hear it come on cranks over but doesn’t start helpppp
Old Feb 28, 2020 | 07:42 PM
Check the obvious first - fuses. After that possible issue with some sensor input to PCM.
Old Feb 29, 2020 | 06:31 AM
Default Montero
It has no fuse problem I checked all of them and it’s not getting any spark I’m thinking crankshaft sensor
Old Feb 29, 2020 | 05:55 PM
Dasoktober's Avatar
Hi Michael,
I've had same issue recently with mine, and found one connector (at control unit near driver seat) with short, causing it shut off random. The wire fail turn off my fuel pump, so, i did a bypass at that connector.
Take your time, check first if the pump is receiving power. If not, do a bypass with a long wire, to test. If goes on, you gonna need time to check all the wire from back to front, passing below the seats, etc. Verify the wires and connectors to the fuel pump.
Kahuna
11
Feb 8, 2011 09:57 PM
Skiddy
Mar 10, 2009 05:01 AM
hoosierdaddy_87
Jul 20, 2006 10:59 PM
thagruvthang
Mar 30, 2006 03:41 PM
jjenkens
Dec 10, 2005 01:09 AM
