EGR Temp sensor switch 3.5 dohc 24v 1996
Old May 19, 2007 | 11:37 AM
johcalhoun's Avatar
Default EGR Temp sensor switch 3.5 dohc 24v 1996
Hi Folks, Newbee here!
My question reguardsa 1996 Montero SR. 145,000 miles. I had a new timing belt & plugs/wires recevtly installed by a (friend of a friend). When I got it back I discovered that the "Temp.Sensor Switch" under the EGR vaulve was not plugged in (electrical) and I can not find anywhere to plug it in to?
The ( friend of a friend ) claims it was not plugged in when he did the repairs. I pulled the upper intake off and still can not see anywhere to plug it. Any help / advise will be greatly appricaited!
Thanks John
Old May 21, 2007 | 10:53 AM
mxmikie's Avatar
Default RE: EGR Temp sensor switch 3.5 dohc 24v 1996
the temp sender is on the front of the engine next to the upper rad hose housing
Old May 21, 2007 | 01:39 PM
johcalhoun's Avatar
Thanks,
But not the water temp sending unit. This one is located on the back left of the intake (facing the enigne) under the EGR vaulve.
Thanks Anyway,
John
Dumbo45
Jan 23, 2009 09:29 AM
mfawaz
Oct 27, 2008 12:42 PM
96eclipsedohc
Aug 5, 2007 11:43 PM
96eclipsedohc
Jan 27, 2007 07:33 PM
