Fog Lights for 00 Montero (Pajero) - Info on installation and procedure
Old Mar 28, 2008 | 06:47 AM
nicolaselias's Avatar
Default Fog Lights for 00 Montero (Pajero) - Info on installation and procedure
Hi everyone, I was wondering if I could receive any help on this..
I own a 00 Mitsu Montero (Pajero) that didn’t come stock with the fog lamps. The stock lighting of the car is somewhat deficient (in my opinion) for when you are on a country back road, which oddly is where this vehicle was designed to be. Is it possible that you can advise me firstly on where I can get the fog lamps (OEM or aftermarket, doesn’t matter) and then the procedure for installing them?
Will electrical work will the vehicle require? Will it need any new relays or fuses etc? Also, what button or **** in the car will I use to control the fog lamps as it will not be installed at this time?
I also wanted to know if these fog lamps will be able to function WHILE the high beams are engaged as this is not illegal where I use the vehicle..
Thanking you,
Nicolas
Old Aug 5, 2008 | 10:52 AM
Default RE: Fog Lights for 00 Montero (Pajero) - Info on installation and procedure
I think It may be smarter for me to go with a bi-xenon kit to improve the lighting but considering the lens design, how do you think this will work out?
Anferney
Jan 26, 2015 11:36 AM
Jims M
May 1, 2011 07:52 AM
blueb16
Feb 27, 2011 01:33 PM
thecrowforever
Apr 14, 2008 02:38 AM
m3kgt_99
Aug 17, 2005 10:13 AM
