Freewheel switch leaking
Old Aug 25, 2005 | 11:36 AM
km_stevens's Avatar
Default Freewheel switch leaking
I got a 01 Montero and the freewheel switch is leaking gear oil. Does anybody have any advise on this?
Old Sep 14, 2005 | 07:08 PM
DarkManC's Avatar
Call yor local Mitsu Dealer service dept...Give them your VIN and they will check to see if that freewheel switch is on recall.I do believe it has a recall...Have seen many changed here at the dealership.
Old Sep 20, 2005 | 08:24 PM
Joel_CA's Avatar
Default RE: Freewheel switch leaking
There IS NOT recall for this part. But there is a TSB issue by Mitsu involving an updated part. You can purchase the updated part and replace it yourself as it is NOT that complicated of a procedure. If you switch the old part and new part fast enough, you won't even loose no more than a couple of tablespoons of gear oil. No need to drain 1st. Depending on when you purchased you Montero, you might still be covered under warranty.....
Good luck!
Joel, CA
01monterob
Jan 8, 2014 12:52 PM
MonteroSport 04
Dec 18, 2013 07:57 AM
otaviofilho
Jul 19, 2011 08:25 AM
aalkukhun
Jun 3, 2011 10:31 PM
Dumbo45
Jan 23, 2009 09:29 AM
