Gen1 Montero not firing up
Old Aug 8, 2016 | 12:18 AM
44opie@gmail.com's Avatar
Angry Gen1 Montero not firing up
Hey everyone! I'm Michael and I just recently bought a Gen1 Montero that needed a new head gasket. Started up great before I replaced it and now it won't fire up. I had to remove the distributor and I've brought it to tdc multiple times and adjusted the points. I have spark and fuel. It's cranking pretty fast and I think compression might be the problem but where is it leaking out? Could it be on the exhaust stroke? I've been trying to figure it out for a week and its getting pretty frustrating, anyone that can help?
Old Aug 8, 2016 | 12:39 PM
Check your timing. It's possible that you did not get it aligned correctly after reinstalling heads. That could result in low compression and no start condition.
Old Aug 8, 2016 | 05:27 PM
Should I use a OBD II scanner to read code or a timing light? Sorry timing is not my forté and I'm tired or working until 1 am after a 12 hour day
Old Aug 8, 2016 | 08:20 PM
Nether one will show you what you need to look for. You have to open up the timing belt covers and see if all of them line up when the engine is at TDC.
monty4sale
Aug 10, 2015 11:34 AM
tancoon
Mar 30, 2010 08:24 PM
tancoon
Mar 30, 2010 07:34 PM
z168
Oct 9, 2008 12:01 AM
horine
Apr 13, 2004 02:49 PM
