Grinding Noise when hitting bumps
Old Apr 5, 2011 | 02:44 PM
mothman52's Avatar
Dang, Sloop, sounds like it's better than fixed. Thanks for the -30-
Old Apr 5, 2011 | 03:00 PM
Thanks for the update. Glad it was an easy fix.
Old Apr 5, 2011 | 03:09 PM
FancyLady2012's Avatar
Originally Posted by mothman52
Sloopjoshc wote:
And fancylady, welcome to the forum! So you said you fixed the problem but you haven't fixed the problem? So is your grinding still happening? If they replaced your CV joint then you probably have a bad bearing. Jack your wheel off the ground and see if you can make it grind as you spin it, then grab it by the edges and push and pull it towards then away from the car. If it's bad, you should feel looseness and hear a grinding noise or a metalic "thunk."
I believe im gonna try that, thanx again for your replies.
Old Apr 5, 2011 | 03:57 PM
mothman52's Avatar
Ok, FancyLady, let us know how it goes. If that's not it then we can move onto some other diagnosis...
Good luck!
Chef
Sep 26, 2014 05:22 PM
dokthor74
Jul 28, 2014 12:54 PM
wedgen
May 11, 2010 02:07 PM
rallyendeavor
Jul 20, 2006 11:22 PM
