Harmonic balancer
Old Mar 15, 2022 | 03:20 PM
Jimmy Talley's Avatar
Default Harmonic balancer
I am replacing the water pump in my 1999 Mitsubishi montero sport 3.5 and I'm having trouble with the balancer. The puller I got from the local parts place will not work, the bolts are too small. I need to know what size bolt I need so I can wield something up to pull it with.. your help is appreciated.
Old Mar 15, 2022 | 10:21 PM
Naeos_Valkarian's Avatar
Once you remove the harmonic balancer bolt, it should just come off. If it does not, try whacking it a few times with soft mallet from different angles. A puller should not be needed for this job. Some form of bolt loosening agent could be used to aid in this process.
Harvey32
Jul 21, 2015 10:27 PM
mlduncan96
Jan 14, 2015 03:40 PM
Clay_Assassin
Oct 15, 2008 09:33 PM
420a
Nov 4, 2007 09:03 PM
