Harmonic Balancer Removal
Old Oct 10, 2008 | 07:02 AM
Clay_Assassin's Avatar
Default Harmonic Balancer Removal
I need a little help guys.
My wife drives a nice '01 eclipse spyder. Yesterday, the Harmonic Balancer / Crank Pully fell off the car![:@][:'(]
Problem is, only the pully part came off, not the rest of the balancer. So now it needs to be replaced.
I've done this job on other cars, but not a mitsubishi. Can sombody please help?
I dont see a way to mount the "normal" puller to the balancer to remove it. Do I need a special puller?
Do I need to replace the crank bolt as well? (My other cars have a torque to yeild crank bolt, so it's replaced upon removal)
Any help or tips you guys could provide would be greatly appreciated. I need it!!
Old Oct 10, 2008 | 06:20 PM
Default RE: Harmonic Balancer Removal
Looks like nobody could help, but I had to get the job going today. Since nobody knew, I'll post what I found:
The Harmonic balancer does not require a new crank bolt on the Eclipse. Other models mitsu's do, but not the eclipse. No puller is required either on the 6 cyl gen 3 model. Jobs dont get any easier than this one. An impact gun on the crank bolt and the balancer is off in a heartbeat. if you try to do it by han, you may have problem keeping the engine from turning. I didnt know an easy way to stop the engine, so I used the impact gun.
Old Oct 15, 2008 | 09:33 PM
Invader_Akira's Avatar
I've had to do that as well... that thing was so tight that it broke socket piece being used to take it off...
can-am
Nov 30, 2014 10:44 AM
tOYBOX13
Dec 16, 2010 11:46 AM
usedsub
Jun 21, 2009 04:04 PM
cptkid570
Dec 14, 2005 12:59 PM
Timmay
Sep 26, 2005 06:15 AM
