04 Endeavor 3.8 harmonic balancer removal problem
Old Nov 29, 2014 | 03:37 PM
can-am's Avatar
Default 04 Endeavor 3.8 harmonic balancer removal problem
Balancer slides back and forth some on the crank but won`t come off. When you try and pull it off there is suction that pulls it right back on. Could someone tell me the procedure? Don`t want to do something wrong. Thanks in advance!
Old Nov 29, 2014 | 06:51 PM
can-am's Avatar
OK what is going on is the bottom timing belt gear is coming off with the balancer and the tension of the belt is pulling it back in. That`s what the suction is. So what do I do to get the balancer off without the gear coming with it?
Old Nov 30, 2014 | 10:44 AM
can-am's Avatar
I did not know the timing gear had an alignment pin on it that went through the balancer. After heating up the pin I put a little outward pressure on the balancer and tapped the pin and the balancer came right off. Anyway all is good now.
I forgot to mention that the reason I was taking it apart was to replace the timing belt tensioner because I had that awful cold engine start-up noise.
tOYBOX13
Dec 16, 2010 11:46 AM
usedsub
Jun 21, 2009 04:04 PM
Clay_Assassin
Oct 15, 2008 09:33 PM
cptkid570
Dec 14, 2005 12:59 PM
Timmay
Sep 26, 2005 06:15 AM
