Help 98 mitsubishi montero amplifier location!!
Old Nov 18, 2010 | 10:11 PM
sakpase's Avatar
Default Help 98 mitsubishi montero amplifier location!!
Hey! I am installing an aftermarket radio in my 98 Mitsubishi Montero in my car but it seems like i have to bypass the amplifier in order for the radio to wok. Any help locating the amp would be appreciated. Thanks
Old Nov 20, 2010 | 12:40 PM
redturboeclipse's Avatar
it uses a din cable, you automatically bypass the amp when you use a standard wiring harness (not the MITAH that comes with din plug)
Old Nov 21, 2010 | 03:49 AM
sakpase's Avatar
I am using a standard wiring harness and the car speaker wire is not part of the wiring harness. There is a separate plug that goes on the old radio that have the speaker wires, i cut that plug and see if i could use the speaker wires from there but there is an amp in the car. I want to find out where the amp is located so i can bypass it.
Old Nov 21, 2010 | 01:29 PM
then you got the MITAH adapter. 90s and early 2000s mitsubishis have this setup if the premium infinity audio is installed as an option or standard.
SOME have parallel wiring because not all come with the infinity audio standard. good example is the mitsubishi eclipse from 95-99.
even if they don't have the inifinity stereo option its wired still for the deck to power the speakers
im not sure on the montero sport, based on what your saying apparently its just the proprietary din cable.
your right cutting it wont help because those are like RCA outputs to the amp. don't know where its located your going to have to start pulling panels, check under the seats, etc.
that amount of work i would just buy a new 4ch amp and redo the entire wiring.
i could be wrong, show me a picture of the harnesses behind the deck. im very familiar with mitsubishi car audio setups from mid 90s to early 00s.
Old Nov 22, 2010 | 09:30 AM
sakpase's Avatar
Hey! I will see if i can take a pictures for you. The car is for my wife's mother. Like you said it's a din cable.
roybliz
Sep 14, 2010 07:36 PM
se7en
Sep 14, 2010 07:31 PM
redturboeclipse
Aug 2, 2009 10:50 PM
e46fanatik
Jul 19, 2005 02:52 PM
aznbballa4lyf
Jan 1, 2005 03:44 PM
