Help with odb codes please P0171, P0174 & P0401
Old Nov 27, 2017 | 03:59 PM
advisual's Avatar
Default Help with odb codes please P0171, P0174 & P0401
My 03 Montero Sport
Started throwing the following codes;
Current Fault Log
P0171: System too Lean (Bank 1)
P0174: System too Lean (Bank 2)
Pending Fault Log
P0401: Exhaust Gas Recirculation Flow Insufficient Detected
Any help would be appreciated.
Old Nov 27, 2017 | 05:26 PM
Most likely you have a vacuum leak somewhere in the intake manifold. Check the rubber intake hose after the MAF (after air cleaner) and up to the throttle body. With the engine running at idle, flex the hose, move the ends near clamps, and see if you can spot any areas where you will hear loud hissing - air entering system unmetered. It is also possible that one or more vacuum hoses that are on the intake manifold have disconnected or got a crack in them and allowing extra air to come in. Check/trace all the vacuum hoses to make sure they did not disconnect/break.
EGR error most likely is a secondary to System Lean.
Old Feb 23, 2018 | 04:22 PM
tonahtiu's Avatar
In my case I mark error just after they tuned it with buoy
redturboeclipse
Jun 12, 2017 10:58 AM
yanclan
Sep 6, 2015 02:21 PM
CHIKE
Mar 10, 2014 09:34 PM
pax62
Feb 20, 2012 08:22 AM
ryan51173
Jan 10, 2011 06:16 PM
