Replaced timing belt and water pump, now have oil leak
Old Jul 3, 2007 | 08:17 PM
adamsstreetauto's Avatar
Default Replaced timing belt and water pump, now have oil leak
I am working on a 2002 Montero Limited, 3.5. I just put on a new water pump, and timing belt, idler pulley, and tensioner pulley. I reassebled everything, and on startup, had a huge oil leak. It appeared to come from the crank seal area, or somewhere in the lower engine area. Seems to only leak under pressure. Now that everything is apart, I cannot locate the leak. Any great ideas?
Old Jul 4, 2007 | 01:15 AM
mxmikie's Avatar
Default RE: Replaced timing belt and water pump, now have oil leak
check around the tensioner
Old Jul 5, 2007 | 01:03 AM
matthew_m75's Avatar
i've got a 97. dont know if its the same but my oil filter and oil sender unit are right there maybe one got damaged during R&R
Old Feb 23, 2018 | 05:43 PM
2001Mitch3.5XS's Avatar
Double check to make sure that all the bolts were put back in place.
raycam2kx
Feb 21, 2008 11:08 PM
Wi_Fibre
Jan 16, 2008 12:17 PM
raycam2kx
14
Oct 6, 2007 08:31 PM
raycam2kx
Aug 16, 2007 08:33 PM
robfrey1
1st Generation
Mar 9, 2006 01:31 AM
